340 wheel weight bolts
Brian
02-01-2004 19:36:20
I am picking up a set of wheel weights for my 340 rowcrop tommorow and would like to know what size and how many I need for each wheel. Thanks for any info.
Al L. in Wisc.
02-02-2004 21:46:25
 Re: 340 wheel weight bolts in reply to Brian, 02-01-2004 19:36:20
You getting used weights (maybe that is all they have, I don't know). I could use some weights. Will see tomorrow morning how the plowing goes w/o weights/chains.
BIG JOHN
02-02-2004 19:07:27
One thing that no one has menchioned is that these need to be square head bolts because they are recessed into the weight.
Maybe you already knew that.
GOOD LUCK
Randy in NE
02-03-2004 08:58:56
 Re: Re: 340 wheel weight bolts in reply to BIG JOHN, 02-02-2004 19:07:27
I found a place on the internet that sold square head bolts. Not cheap. If you are going to put them on and leave them on just wedge a big screw driver in against the head of the hex head bolt to get it tightened. The other thing you can do is to use readi-rod and put a nut and lock washer on both ends. Then you can bolt all of the weights on together. More work to get them all on but can be done.
Farmer Bob
02-01-2004 22:11:40
Just measured mine...3/4"x4-1/2 will do fine for the regular one piece weight. If you want to have a little sticking out of the nut with a good lock washer behind the nut you could go to 5" length. I'd use grade 5 or 8.
rustyfarmall
02-02-2004 04:31:04
 Re: Re: 340 wheel weight bolts in reply to Farmer Bob, 02-01-2004 22:11:40
I'll second the vote for 3/4 inch by 5 inches long, at least a grade 5. You will need a total of 8 bolts,nuts, and lock washers. You might want to look for these at your Case-IH dealer.
I might also add that for guaranteed traction in snow or on ice, you just cannot beat a pair of tire chains.
Bill in Orono, MN
02-01-2004 20:44:34
For $50 or so per pair (used of course) 3 pair will do if you don't have fluid in the tires. Just why are you needing weights anyhow. Traction, impress the ladies, sink faster in quicksand?:)
brian
02-01-2004 20:56:15
 Re: Re: 340 wheel weight bolts in reply to Bill in Orono, MN, 02-01-2004 20:44:34
need to know what size bolts to bolt them to wheels and need the extra weight for traction plowing snow
