IH 786 For Tractor Pulling
Ron Midd
02-02-2004 12:56:09
Just wanted to know if anyone else pulls a 786 IH, and do you run a turbo.
Larry B.
02-03-2004 05:43:31
 Re: IH 786 For Tractor Pulling in reply to Ron Midd, 02-02-2004 12:56:09
Do you mean a 766 that runs a 360 diesel like some of the 886? I Know of a 686-886-986 but never heard of a 786.
GP
02-03-2004 09:41:02
 Re: Re: IH 786 For Tractor Pulling in reply to Larry B., 02-03-2004 05:43:31
The 786 was the successor to the 766 just like the rest of the 86 series replaced similar 66 series tractors.
scotc
02-02-2004 23:57:01
I've only seen a 786 pull once, lots of weight there for the power. If you can change engines and want to pull lighter classes I'd go with an 06 or 56, use a dt360 or dt414 motor. I think later 786 came with the d360, may need a manifold change for a turbo, don't know for sure. One trick to the 756 is that they ran the d310, I think the only real difference between it and the d358 is the crank, if you are in a class that won't allow an engine change, the oil pans interchange. With a 966 the bigger motor is there just need to stick a turbo on it, and it'll also still weigh less than the 786. I don't know if you've got an open or ROPS tractor, I'm assuming its a ROPS. It also depends on how stock it has to stay or how stock it has to look.
