low oilpresure
jerry
02-07-2004 14:54:49
how hard is it to replace the rod bearings on a cub. after about 15minets of hard running i have less than 5psi at idle and 10psi full thotle no load. i am running 40wt catrol oil. the tractor has 30-40psi cold at idle 20degree wheather.i replaced the head gasket this past summer, can i replace the bearings with out removing the head,hood etc.
Kirk
02-07-2004 17:06:23
 Re: low oilpresure in reply to jerry, 02-07-2004 14:54:49
Also check the Relief Valve in the oil pump to make sure it is seating all the way and not stuck open. Good Luck.
Bob
02-07-2004 16:28:55
Check the oil pump, also. I am not familiar with the Cub, but the "A" and "B" engines, etc., are known to have a warped pump cover, and the gasket squeezes out and causes low oil pressure when warm.
Jon
02-08-2004 11:23:25
 Re: Re: low oilpresure in reply to Bob, 02-07-2004 16:28:55
Check your pump but if you still have a problem go to napa and get this Lucas engine oil you will ony need a quart remove a quart of oil from your oil pan and then ad the lucas. My tractor had the same problem did the oil lasted for 5 years and then we slod the tracto and the guy we sold it to said it still runs great.
parts man
02-07-2004 15:22:40
You can do a "roll in" by just removing the oil pan. I'd recomend plastiguaging the crank with the new bearings in just to be on the safe side,, it's cheaper than having a rod come out through the side of the block!!
