Front or rear blade on Farmall 100
Paul in Mich
02-11-2004 10:20:05
I'm cinsidering a farmall 100 to use for snow removal among other things. It is equipped with fast hitch as will as touch control hydraulics. Which is best, rear or front blade? In either case, I still have to convince the Missus that I really do need one more tractor to take up garage space. Any suggestions? Which lie works best?
gene b
02-12-2004 02:22:51
 Re: Front or rear blade on Farmall 100 in reply to Paul in Mich, 02-11-2004 10:20:05
You will like the one on the front better as you can pile it high. The one on my B gets used far more that the one with blade on back.
BIG JOHN
02-11-2004 18:11:37
I have a 135 HP tractor, cab w/heat with a rear blade and I also have a 22 HP tractor open station with a front blade and I always go for the small tractor with the front blade. My neck really appreciates the front blade over the rear blade.
You will need tire chains and weight on the rear or you might as well not even leave the barn.
Paul Shuler
02-11-2004 15:14:52
Hi Paul, I have a blade on the front and back of my tractor. The only thing I use the back blade for is pulling the snow out away from garage doors or cars and what not. The other thing I use it for is the weight, crazy thing is very heavy.The photo is from last Dec. We have not had more than a dusting this year.
Hugh MacKay
02-11-2004 15:01:36
Paul: I don't know whether you have read this in some of my other posts or not so here goes; When I was a teenager my dad plowed snow with then new Farmall 300, ring chains, and a 7' angle front blade that would raise about 6' off ground. In the nearby village about 100 homes, stores, post office. bank, churches, etc. Three guys kept that village plowed out excepting the streets and roads. The tractors were Super A and Super C both with factory front blades and a MF 35 with a loader and snow bucket. We would go to the feed store and were always amazed, the guy with the Super A was doing half of the plowing in the village. I remember coming home from village with dad first winter we had the 130. We drove past where the guy was plowing a driveway with Super A. My dad's comment,"I think we have out snow blade on the wrong tractor." 14 years ago I finally put a fabricated 6' angle front blade on 130. Right now I have snow piled 4 to 5 feet deep both sides of my driveway about 350' to the road. The guy with the big snowblower did help short term. He also put a 3" layer of ice on my driveway. This morning I was down to 9 feet in width. Today pushing old frozen snow back I have now this evening back to 12 feet wide on bottom. I have regular chains and one set of wheel weights. I do wish I had a blade on my fast hitch that would protrude out about 4 feet to one side of tractor, that I could use much like a wing. Don't even think rear blade as prime source of plowing, your neck is just as old as mine.
Oh and about back in my home town, today there is about 200 homes, few more commercial buildings, and at last count 12- 4x4 pickups, 3- skid loaders, 2- 4x4 tractors with loaders and one payloader. They are no faster that the guys 45 years ago. But then the guys back then didn't have coffee shops to sit in and talk about what they didn't have done.
It may have been built by IH as a cultivator tractor but they are one mean little snow plowing machine. If you or the missus aren't convinced, just plunk your little backsides in your automobile, and drive to Strathroy. I guarentee a cure for the unconvinced.
scotty
02-11-2004 11:30:51
Paul, I have been using the front blade for past couple of years. I use chains and an electrical box bolted to the drawbar filled with about 400lbs of weight. It will push a lot of snow!
I think back blade would be tough on the neck.
scotty
Randy in NE
02-11-2004 11:01:29
The front blade is going to be easier to use. It will cause the back end of the tractor to be a little light so you may need either chains or wheel weights, or both. With the back blade you will either be driving over and packing the snow if you pull it forward or you are going to be swiveling around on the seat trying to watch where you are going as you back up if you are pushing it with the blade turned around. Did it as a kid and it got old as a teenager. Now that I am older I don't think that my back and neck would like that very much.
