h jumps out of high gesr
rman
02-14-2004 16:40:51
when driving are h it comes out of high gear sometimes there is no noise is their any adjustmant thanks for help
Burt
02-14-2004 22:03:56
 Re: h jumps out of high gesr in reply to rman, 02-14-2004 16:40:51
You do not have to split tractor,just remove belly hyd. pump and remove coupling between clutch shaft and input shaft to tran. The tran. cover will have to be removed. Replace both 4th/5th slider and tran input shaft/gear. This is the weak place in h and m trans.
Bryce Andreasen (Magnum)
02-14-2004 18:52:41
My '41 H did that when i bought it, and turned out the pilot bearing was out. I bought a new 4th and 5th sliding gear while it was split so it was done all at once, it was pretty worn (5th gear).
Fred Milner
02-14-2004 17:32:12
Most of the time when this happens the 4th 5th slider gear is worn out. They are not made very strong on the 5th side and are shifted while moving most of the time and wear out. You can get them for around $100 but I tryed to post the place to get them and the reply went away. You will have to split the tractor and take the trans. cover off to fix it. Good luck
riverbend
02-14-2004 18:39:53
 Re: Re: h jumps out of high gesr in reply to Fred Milner, 02-14-2004 17:32:12
I don't recall having to split the tractor to get the gears out, but it has been a while.
