130 Hi Crop
Shaggy
02-20-2004 07:27:47
Is a 130 Hi Crop few and far between? I found one thats a 1957 and it physcially decent and has been setting for awhile.
Shaggy
02-21-2004 18:37:56
 Re: 130 Hi Crop in reply to Shaggy, 02-20-2004 07:27:47
Went by the place that has the 130 and its still there so I am off to hunt the people Monday!
Guy Fay
02-20-2004 14:53:48
570 of all types of Farmall 130 HCs were built.
Guy Fay
02-20-2004 16:23:30
 Re: Re: 130 Hi Crop in reply to Guy Fay, 02-20-2004 14:53:48
Distillate and gasolene fuelled. There were no kerosene tractors built of this model.
Kent in NB
02-21-2004 06:19:43
 Re: Re: Re: 130 Hi Crop in reply to Guy Fay, 02-20-2004 16:23:30
Hello Mr. Fay. Just got your new hundred series book. Very nice. Wish there were more pictures of the 200's though. What's next?
Hugh MacKay
02-20-2004 20:01:55
Guy Thank you for that, now I have another question. Most hi clear offsets AV, SAV, 100, 130 and 140 used 19" wheels on front and I believe the spindles were a bit longer as well. I have seen a couple with quite long spindles and 15" wheels on front. It has been some time so I don't remember which model but reasonably sure these were 130s or early 140s. These tractors had been bought new by a government run strawberry farm.
Hugh MacKay
02-20-2004 15:09:38
Guy: Could you elaborate on what you mean by all types.
Hugh MacKay
02-20-2004 07:50:51
Shaggy: They will be quite rare, as a lot of people overlook the 100, 200, 300, 400 and 130, 230, 350, 450, etc. Each of these only built two years, that alone makes them scarce. Hi crops as a percentage will be low also. As a group these are some of the lowest production number tractors IH built. If it's reasonable I'd grab it, if I were you.
Shaggy
02-20-2004 08:29:47
 Re: Re: 130 Hi Crop in reply to Hugh MacKay, 02-20-2004 07:50:51
What would be reasonable? I think it may have a cultivator too. Bad tires (front and rear) and no carb. But the rest is good. $1000 give or take?
Hugh MacKay
02-20-2004 14:30:34
 Re: Re: Re: 130 Hi Crop in reply to Shaggy, 02-20-2004 08:29:47
Shaggy: From your description I wouldn't give anymore. Those 36" tires aren't getting any easier to find. Does it have 19" on front? Carb missing as well and you will undoubtedly find other items that need replacing. I would even try for less, but at same time doubt if you get it for much less. Worth a try. Try and get the seller to put a price on it first, whole lot easier to react to his price.
