smta front wheel/hub
paul
02-21-2004 03:12:58
Previous owner had damage to left frt hub ,my guess is that the frt end came down hard and cracked the spokes that are now welded.Found 2 on e bay off an m are these the same for an smta?I only need one if anyone has one that they would like to part with please e mail me also looking for a battery box.Thanks Paul.
Jim J
02-21-2004 07:28:09
 Re: smta front wheel/hub in reply to paul, 02-21-2004 03:12:58
What is the auction number I can look at the huds and tell if they are the lighr or the heavy hubs
randy hall
02-21-2004 07:16:54
starting with the super m's they cast the wheel hubs a little bigger so they could be machined to fit the rim this way they didn't work loose as easy, and like dave said they are a little heavier made.
Dave W V
02-21-2004 05:39:13
The hubs on most M are lighter than SM. Find one the same thickness as yours where the 3 bolts hold
rim to wheel.Either will work though.
