400 Trans oil change
Mike
02-24-2004 03:06:01
I am going to change rear end oil in my 400. How many drain plugs are there and how much oil do I need? Thank you.
JOEL
02-24-2004 04:57:21
 Re: 400 Trans oil change in reply to Mike, 02-24-2004 03:06:01
Should be two one to the front and one on the back of the rear end. Should hold about 15 gallon of hy-tran.
Wardner
02-24-2004 22:44:20
 Re: Re: 400 Trans oil change in reply to JOEL, 02-24-2004 04:57:21
There are actually three. One big plug (1") at the rear and two smaller plugs (3/8" and 1/2") on the bottom of the center section. Because there are fifteen gallons, I pull the small plugs first to minimize spillage. Some oil gets retained in the belt pulley gear box. Filling from the side or top will fill everything in the rear frame and center section.
