Grrrrrrring Noise in the rearend of an M
BigRed1
02-25-2004 16:49:30
The only time this happens is when I am pulling my tiller tool and get it bogged down. When the tractor really pulls hard (barely moving) there is a grrring or grinding noise coming from the rear end (first gear). Any ideas????
BigRed1
02-26-2004 05:53:43
 Re: Grrrrrrring Noise in the rearend of an M in reply to BigRed1, 02-25-2004 16:49:30
It might be described better as a popping noise or a clicking.....hope this helps in the diagnosis.
Michael Soldan
02-25-2004 21:00:58
Bigred1, is you tiller a rotory tiller running off of the PTO? I was wondering if it was , could it be bearing on the PTO shaft. Another thought is the first gear worn somewhat that would give it a growl. I have an H that growls under load in any gear, I think it is just the nature of the beast. There are likely some guys that can explain rear end noise better than I..good luck from Mike in Exeter Ontario
BigRed1
02-26-2004 11:45:04
 Re: Re: Grrrrrrring Noise in the rearend of an M in reply to Michael Soldan, 02-25-2004 21:00:58
It is a 9 point tillage tool (not rotary)....The sound maybe more like a poping or clicking sound, if that helps any...Thanks.
