300 UTILITY LIVE PTO QUESTION
RON
02-25-2004 23:18:33
I HAVE A 300 UTILITY WITH A LIVE PTO, AND I WANT TO REMOVE IT. CAN I JUST PULL IT OUT LIKE A NOT LIVE PTO UNIT AND PLATE IT OFF OR WILL THE SHAFTS INSIDE THE TRANS NEED TO BE TAKEN OUT? WILL THE COUPLER THAT HOOKS THE IPTO SHAFT THE THE COUNTER SHAFT STAY ON THE SHAFT OR WILL IT BE LOOSE? THANKS ALL..... ..
Hugh MacKay
02-26-2004 05:56:01
 Re: 300 UTILITY LIVE PTO QUESTION in reply to RON, 02-25-2004 23:18:33
Ron: In the Farmalls it was a short shaft with two couplers, Make sure on that second coupler in from pto, you don't want that floating around in there. As I recall the couplers are only held by the shaft itself.
My main reason for posting is to give you a tip on doing this without draining. Just place tractor on a steep down grade, as long as you get front wheels 15 to 18 inches below rears, oil will flow foreward enough, for this. If this is just temperory I used a 3/4" plywood cover and continued using tractor without pto. Beauty of the plywood cover is you don't need to play around with gaskets. Save the plywood, it fits most IH tractors of that era.
Aces
02-26-2004 05:03:12
Ron Drain the rear end first, but you will get a short shaft after you pull the PTO and just cover the hole.
