Another question about a 450 problem
old
02-27-2004 07:52:57
On the hydrolic system the lever that should work the 2 point hitch is unhooked and if you pull on it side ways it will slide right out, is it broken or is there a keeper in there that should hold it in?? The I-T manual doesn't show it very well. I know I can look at my other 450 but thats a lot of work to be able to see in there so I figured I ask you guys first. Thanks again for your help.
26Red
02-27-2004 09:39:22
 Re: Another question about a 450 problem in reply to old, 02-27-2004 07:52:57
There is a pin holding the shaft in. You have to pull the dash and sheetmetal out of the way to fix it. Pretty easy fix, just some work to get to the problem.
