Farmall Super C running bad HELP
Randy Bishop
02-28-2004 14:19:21
I have a 52 Super C that runs fine when I first start it but after it runs for a while and gets warmed up it starts missing real bad. It does it all of a sudden. It will run, but poorly with the choke wide open. Sure would appreciate some advice .Thanks very much.
JLB
03-01-2004 13:23:00
 Re: Farmall Super C running bad HELP in reply to Randy Bishop, 02-28-2004 14:19:21
i have the same problem with my C, i'm told that my float needs adjusment to allow more fuel flow but i have no original measurement to go by. this means a lot of work removing, adjusting and reattaching the carb.. ..... ... maybe someone else knows the correct adjustment?
TractorNut
03-01-2004 12:37:07
Have seen this several times on my JD's, but usually the tractor will die. It was the condensor.
Wayne Swenson
02-28-2004 20:12:36
Take a look at my earlier posting under the heading of coil testing; you could also try cleaning the points and re-gapping them.
Dave_Id
02-28-2004 15:49:46
You could have a bad coil.. also check to make sure you have a good flow on your carb out of the tank.. Maybe the opening in the tank is plugged or the screen is plugged on your glass sludge separator
