I A Farmall tractor
Gene
03-01-2004 15:49:23
I found this week end that I have what looks to be a farmall I A ser#IAA105445 that was at the Pensacola navy satation. I found on the tractor a plate with the tool number 21594 and the dept.number P.W. If any one can help or does case have a record of when and wear tractors were shipped. I belong to the florida flywheelers and this past week ends Farmall show was very good even with the cold wind,Friday it was all of 50deg.a 15mph north wind all day,Sat. it got up to about 65deg. with very little wind and lots of SUN. Thanks ,Gene
Scott
03-05-2004 18:49:13
 Re: I A Farmall tractor in reply to Gene , 03-01-2004 15:49:23
Gene,
Big John is right about the year, it is a 1944. It also is a Industrial A (or A-I). I have been researching these, and can report that there were 838 of them if the information is correct. They are the same as the Farmall A, with the exception that yours should have a foot-throttle between the brake pedals, and a heavy duty square-tube front axle with a torque brace returning back to the rear of the block. Many of these were sold to public highway depts, airports, and military installations. The problem is that there are no delivery records of them that I know of. I've been chasing the issue myself, as I am restoring a '52 Super A Industrial (1 of 5119,or 1 in every 21 tractors) which in '52 was marketed as International, rather than the masses of Farmalls. All of the Super A's were made in the IH Louisville, KY plant, I cannot confirm the earlier A's though. I would recommend getting ahold of Guy Fay's or Ken Updike's Tractor Data Book for more information on the earlier Industrial A's.
E-mail me if you have more to share. Good Luck.
BIG JOHN
03-01-2004 18:28:38
Not real sure what you are asking but hope this helps. Your tractor was manfactured in 1944. Serial numbers for 1944 were from 96390 to 113217. There was no production listed for 1943 so these numbers cover everything from 1943 to 1945. It will be your guess about the exaxct date your tractor was built.
There are casting date codes on the major parts and you can check those. If you go to the left side of this page in the "Research & Info" section you will find lots of help in this department.
GOOD LUCK
