424 hyd.pump
andy
03-01-2004 17:34:47
have 424 with loader will raise loader but wont pick up any weight. is pump bad or is it a check valve problem?
Gary in MOzarks
03-03-2004 10:51:22
 Re: 424 hyd.pump in reply to andy, 03-01-2004 17:34:47
RU running the loader off the quick disconnets next to the battery? Some tractors have extentions to move the remotes forward under the brake pedals. There is a flow control knob that has to be open next to and below the seat left side plus an isolating knob right side that has to be closed if you are using the remotes. Yes there is a 2200psi relief valve that could be open plus two filters a 100 mesh suction filter under the seat where the pipe comes out of the tank and another one next to the shifter either of those could be clogged. Hope this helps. Its from the operators manual I have
