Help need some parts
old
03-03-2004 10:26:43
We have a Farmall 450 with a few missing parts on the Hydrolic valves IH part numbers are 363080R91 its a Link and 361648R11 lever. IH dealer says they are retired parts so I can't get them from IH/case and I have tried value bitl and local salvage yards any body know where I might find these parts. I need them pretty bad since with out them one of the hydrolic levers will not work. Thanks for any help
Jerry
03-05-2004 05:04:42
 Re: Help need some parts in reply to old, 03-03-2004 10:26:43
If I`m closer I probably have what you are needing as I have an extra valve/ res assy.I am in central NY at Mexico.
Dave W V
03-03-2004 13:46:26
I have the parts. 304-988-9857
scotty
03-03-2004 11:34:49
Old, Are you talking about the two links on the bottom of the lever for the hyd valve? I made some of those at work the other day, I was running the loader on my Massey and one of the links broke. They are nothing more than sprocket chain sections with pins through them, so the hyd lever has a pivot. Any good hardware supply store should have them. I hope I understood your question correctly!
scotty
old
03-03-2004 13:01:06
 Re: Re: Help need some parts in reply to scotty, 03-03-2004 11:34:49
One of the parts is the piece that is held on with a roll pin on the end of the lever shaft and the other is an arm that goes from that piece to the valve lever. When hooked up it would look sort of like an upside down L, whit the top of the L on the shaft and the - part of the L going to the valve control
