IH 240 PTO/Belt Pulley oil seals
David
03-03-2004 13:48:17
I have an IH 240 Utility that needs oil seals for the PTO and Belt Pulley. The numbers from my parts
manual are 48 114 D and 367 810 R91 (no.s appear to be the same for Farmall 200 and 230). Any ideas would be greatly appreciated.
Haas
03-03-2004 20:31:14
 Re: IH 240 PTO/Belt Pulley oil seals in reply to David, 03-03-2004 13:48:17
Don't forget the O ring seal for the belt pulley, 358208 R1. That is an O ring that goes under the pulley housing assembly. There is not gasket there, only shims to adjust the gear mesh. So there is an o ring seal on the inside to stop oil leaks. You have to pull the belt pulley housing off to replace it. If you don't have leaks around the shims, best to not mess with it. You can replace belt pulley shaft seal and the PTO seal without removing the housings. Getting the PTO seal out may be a chore though. Also note there is a bushing on the belt pulley shaft that the seal runs on. You have to keep the pulley on the shaft or the spacer all the time to avoid loosing that seal bushing.
CNKS
03-03-2004 19:12:11
If those are the 240 part numbers, what is your question -- just buy them.
David
03-05-2004 17:54:57
 Re: Re: IH 240 PTO/Belt Pulley oil seals in reply to CNKS, 03-03-2004 19:12:11
I have contacted a number of parts places with no success. My question should have been does anyone know a source for these parts?
