Question for Bernard le mécano
Mac
03-05-2004 14:51:17
Does 485 version of CIH380B share same hyd remotes as CIH485 and IH485. The pump is bigger (17gpm) than ag version I think, but not sure if that would cause a difference in remotes. If they are same, how many models share the same 485 transmission housing(484, 474, 585 etc)?
Thanks, Mac
Bernard le Mécano
03-05-2004 20:46:07
 Re: Question for Bernard le mécano in reply to Mac, 03-05-2004 14:51:17
Hi Mac, it's the same flow then a 885,895 and 4200 serie. Those tractors have 18 GPM, 3 GPM for the steering system, by a priority valve and 15 GPM for hitch and remote. You can by a up-grade plate and gear kit, from CASE-IH, for early version( 454,484,574,684. For the housing, the serie start with 454 and finish with 895. 4200 serie have syncro in range and reverse. The remote valve have change with 84 serie ( 3 bolts on 54 and 74 or 4 bolts on 84,85,95 version) I think the remote (84 and 85 serie) are the same. Check with a dealer for parts numbers. Bernard le Mécano Québec Canada
