loose sterring on 100
jeeper
03-18-2004 16:58:33
anybody no how to get the play out of stering? it looks like you can turn it about half way before it starts to move tires. thanks for any info.
jeeper
Hugh MacKay
03-19-2004 03:09:50
 Re: loose sterring on 100 in reply to jeeper, 03-18-2004 16:58:33
Jeeper: Your tractor should have the keyway on tapered shaft for the steering control arm. That key plus the one on the gear inside the box can cause the problems you are experienceing. Those are woodruff keys and you will most likely have to modify oversize keys by grinding to get that tight.
BOB
03-18-2004 20:27:13
Jeepers, look under your steering box and the arm that drag links hook to and see if it has a nut or a squire head with bolt and nut key way broken? or loose
BOB
03-18-2004 20:26:15
Jeepers, look under your steering box and the arm that drag likes hook to and see if it has a nut or a squire head with bolt and nut key way broken? or loose
