Super C; could it be wired wrong?
John L.
03-18-2004 18:17:52
I bought a 52 Super C and it had recently had the gauges and ignition switch replace. It is the 6 volt system and it charges and acts normal in all respects.
It starts real good and runs well for about 10 minutes or less, then starts slowing down and finally stops and won't restart eventho the starter turns over well.
When it starts slowing down and stops, I removed the gas line and the gas flow is ample and its quality is good. So I don't think that I have a fuel problem.
I notice the coil is warm when it dies but doesn't seem to be hot.
If the tractor sets for 30 or 40 minutes, it will crank right up and run another 10 or so minutes. It will run the same time pulling or at idle I believe.
What do you think?
Phlogiston
03-18-2004 19:22:55
 Re: Super C; could it be wired wrong? in reply to John L., 03-18-2004 18:17:52
Yep, bad coil.
Phlogiston
Jeff in Ontario
03-18-2004 19:22:30
I've had that same problem before....it was the coil no doubt. --Jeff
Hugh MacKay
03-18-2004 19:02:44
John: It is without question the coil.
Nate the Great
03-18-2004 18:27:15
sounds like your coil is shot. same sort of thing happend a while back on my A. would run fine, then die when it warmed up. once it cooled it would start fine.
John L.
03-19-2004 10:12:31
 Re: Re: Super C; could it be wired wrong? in reply to Nate the Great, 03-18-2004 18:27:15
Thanks for all your responses. John
