super m hyd.
Garry coleman
03-21-2004 12:23:13
I have I believe is a aux.rear hyd.box muonted under the fuel tank, I use. are you able to get hyd. power out of the side of main case? what manuel explans this?
Aces
03-21-2004 13:58:27
 Re: super m hyd. in reply to Garry coleman, 03-21-2004 12:23:13
Garry If you have a SM with a control box under the back of the gas tank and a pump in front of the distributor you have live hydraulics. The box under the tank controls the hydraulics there is one outlet on the right and two on the left side the right front one and the one on left side can be used to operate one way cylinder the let rear one is a slow drop for the part of a cultivater that went behind the rear wheels and should not be use for other things.
