Best Spark!
RC
03-22-2004 17:55:01
What plug will get you the best spark for a 6-volt H with mag system? Can you use the new type bosch platinum plugs? Any help will be appreciated.
riverbend
03-23-2004 12:13:53
 Re: Best Spark! in reply to RC, 03-22-2004 17:55:01
Most guys use AC or Autolite. You might take one of the old plugs out and see what you think about a Bosch platinum plug working. Buying a set of manuals is money well spent.
Stan(VA).
03-24-2004 04:25:07
 Re: Re: Best Spark! in reply to riverbend, 03-23-2004 12:13:53
I would be interested in seeing other's thoughts here too. A retired mechanic I know has told me several times not to put platinum plugs on anything without an HEI ignition or a hotter coil because the platinums are actually harder to fire (meaning takes a higher voltage) than the standard plugs. I have seen no documentation either way, just wondering other's experience?
Stan(VA).
RC
03-24-2004 13:42:09
 Re: Re: Re: Best Spark! in reply to Stan(VA)., 03-24-2004 04:25:07
Thanks guys for your thoughts. I do not think I will put Bosch platinum plugs in since I have not seen a cross-over yet and the higher voltage issue makes sense. I have emailed Autolite people at Honeywell but they have not gotten back yet. I will post anything I hear as it sounds like a few other guys would alos be interested.
