other engines in a 560
Chris Brown
03-28-2004 14:57:53
Got a 560 gas (previously diesel) loader tractor with a gas combine engine in it right now. I don't need alot of power,45 hp or so but I want a diesel engine to put back. I have looked around for a 282 to put back and have not had much luck finding a good un. What else will fit in there? What about the wd9 engine? I am pretty sure the 221 or whatever it is in a 460 will work. I can't afford to run it like it is at 5 gal per hour doing loader work.
I just want to know what to look for when I go to the bone yard. Thanks
steveormary
03-28-2004 17:36:37
 Re: other engines in a 560 in reply to Chris Brown, 03-28-2004 14:57:53
Chris Brown; 5 gal./hr for loader work seems pretty excessive to me. Are you running it hard,is your engine tuned peoperly?
steve
Chris Brown
03-29-2004 04:30:05
 Re: Re: other engines in a 560 in reply to steveormary, 03-28-2004 17:36:37
Yes it is tuned good and running perfect. I think it could idle 4 gallons in a hour. It will burn 5 gal per hr pulling a 15 " disk or 4-5 just driving around.I was told it was a 263 engine but who knows,it sure has alot of power,it'll run full throttle all day in 4th gear with that 15"disk,it has alot more guts than the old 282 D had. I'd like to swap it to someone for a diesel engine,it'd be a good candidate for a pulling tractor engine.
K.B.
03-28-2004 16:14:56
The 221 is the gas engine for the 460. The 460 Diesel had a D-236. The D-236, D-282, and D-301(early 715 combine) all use the same block and will interchange with each other fairly easily. I highly doubt that a WD-9 engine will fit without tons of modification. If it was me, I would hold out for a good 282 straight out of a 560. Shouldn't be that hard to find.
dennis
03-28-2004 16:01:55
try looking for a d-236, same line as 282, 301
good luck
Chris
03-28-2004 17:36:15
 Re: Re: other engines in a 560 in reply to dennis, 03-28-2004 16:01:55
I guess I am going to go a little farther away from home. All the junk yards around here are exhausted of 282's.they have tons of gas burners. I'll keep looking
steveormary
03-29-2004 08:51:48
 Re: Re: Re: other engines in a 560 in reply to Chris, 03-28-2004 17:36:15
Chris:
I know that the Farmall gassers are thirsty critters but turn up alot of power. Example. Neighbor had a 450 gas and a chisel plow. Loaned the rig to another neighbor. When neighbor returned the rig to the owner he claimed he could get 11 ft/gal. Good luck finding a deisel.
steve
Chris
03-29-2004 09:58:19
 Re: Re: Re: Re: other engines in a 560 in reply to steveormary, 03-29-2004 08:51:48
"11 ft/gal" thats funny!
