350 UTILITY
Joe
04-01-2004 16:31:08
Hello ,I fell in to a 350D utility diesel, it was free but had to have it shipped($900.00). Sounded like a good deal. Tractor looked decent, very little rust, brand new back tires. After asking you all a few qustions and changeing filters got it running, about 15 minutes later, bammm, theres a rod sticking thru the block rigth into the gas filter, I was shocked, couldnt belive this, I have no idea why this happened, it was full of oil and anti freeze, so can this be fixed, is it worth fixing or will this be worth anything to anybody the way it is, ok i have to go back to crying now,Thanks
JBelt
09-13-2006 12:27:07
 Re: 350 UTILITY in reply to Joe, 04-01-2004 16:31:08
I haven"t seen any follow-ups lately about your 350 diesel. I am just about done restoring a 350 diesel and may be interested in parts from yours if you are not going to pursue trying to fix it. By the way, continental D-193 parts are very hard to come by. Good luck.
JLE
04-02-2004 17:34:30
Joe: where at in MI, I'm in the SE part. N of Toledo, OH Jim
joe
04-02-2004 18:00:44
 Re: Re: 350 UTILITY in reply to JLE, 04-02-2004 17:34:30
im about 45 minutes north of detroit
tom
04-02-2004 03:38:31
I have a Continental G193, gas engine that will bolt right in, same block. Will give you a little more power than the IH 175
JOE
04-02-2004 04:25:34
 Re: Re: 350 UTILITY in reply to tom, 04-02-2004 03:38:31
How big of job would that be, also what shape is you gas motor in, and also how much $$.
where are you located
Thanks alot
Tractor Dan
04-01-2004 17:02:31
sorry to hear what happened i have a farmall 350 diesel i will let you know parts wont be cheap for the continental gd 193
i got alot for it at the local auto parts store but also here is a place with some parts>Link
where are you located?
and if you wernt going to fix it would you like to get rid of it
joe
04-01-2004 17:29:38
 Re: Re: 350 UTILITY in reply to Tractor Dan, 04-01-2004 17:02:31
Thanks for the info, not sure what im goin to do wiht it, Im IN Michigan
Jonathan
04-01-2004 16:52:50
Your not alone. I was using my Farmall H last week and the rod bolt heads broke on the number 4 cylinder and let the rod go, and the crank slapped it through the side of the block. I was very shocked because the tractor had never knocked or showed any indications of problems and I had just driven it to where it was parked at a high idle when the rod suddenly let go, now I'd have thought it would have let go when I had the tractor at full throttle just a few minutes before, but instead it went at a lower RPM with no load on the engine. The engine had plenty of oil.
