Re 3-pt hitches for Farmall C
Jay
04-03-2004 13:09:25
We are in the process of resoring a Farmall C that we have inherited from my grandfather. The tractor runs like a watch, and I am very interested in using the tracor for cutting grass with a brush hog. can you get a 3 point for a model c and where would I get one? Also does anyonw know if you can buy a loader for same?
The hydraulics even work like a charm.
please let me know
CNKS
04-03-2004 13:16:58
 Re: Re 3-pt hitches for Farmall C in reply to Jay, 04-03-2004 13:09:25
3-point hitches are available from www.saginaw countytractor.com. Has it's own cylinder, does not lift off the rockshaft. Depending on the weight of your mower, you may need weight on the front end. The web site will not list a 3-point for the C but he does have them.
Brian Young
04-04-2004 12:18:02
 Re: Re: Re 3-pt hitches for Farmall C in reply to CNKS, 04-03-2004 13:16:58
Perhaps a Fast hitch/3 pt. adaptor that was made just for your dilemna would be an economical answer for the need you have.
Jay
04-05-2004 04:30:39
 Re: Re: Re: Re 3-pt hitches for Farmall C in reply to Brian Young, 04-04-2004 12:18:02
re: 3 point for Farmall C
Brian has suggested a "Fast Hitch" three point.
any idea where I would get one, or how much?
Thanks
BillWV
04-05-2004 04:51:43
 Re: Re: Re: Re: Re 3-pt hitches for Farmall C in reply to Jay, 04-05-2004 04:30:39
I think Brian is talking about a kit to allow a factory IH Fast Hitch to use 3ph implements. If you don't already have a Fast Hitch, it won't help you any. I called Saginaw County about the 3 point kit for C's and Super C's; it was about $800 all told. They sure are nice looking units. If you're thinking about it, you should scoop up the cultivator axle clamps that are on e-bay right now; you'll need them for the 3ph kit, and Saginaw said they charge $50 for them (if they have any).
There is another company that makes 3 point kits that uses the factory lift rather than separate cylinders. Worksaver, I think. They are considerably cheaper than the Saginaw units, but most people prefer Saginaw.
Good luck,
Bill
