H FARMALL AFTER MARKET FIRECRATERS?
redcub
04-07-2004 18:37:42
Got the head off the junk 1951 H and to my suprise...dome pistons underneath!!! The bore of this H is 3 7/16". The pistons are aluminum with 2 raised places to one side of the tops. The pistons say: conformatic , P762A (small)M N (over top each other on the M&N). Three of the rods have the number "43785DD (IH)" on one side and 13cc5(?) 01037 W4-1 on the other side. Bought the head for $250.00 and the pistons for $50.00! WHO MAKES THESE PISTONS? WHERE CAN I GET RINGS FOR THE PISTONS? ANY OTHER SUGESTIONS? What compression gain can I expect with these pistons?
randy hall
04-07-2004 19:56:18
 Re: H FARMALL AFTER MARKET FIRECRATERS? in reply to redcub, 04-07-2004 18:37:42
tractor supply used to call their domed pistons 'conformatic'
gene b
04-07-2004 18:59:30
Just measure the thickness of the grooves and the bore and there should be no problem. If you dont have any luck send me an e-mail and we will go from there. These things are standard and should not be hard to get. That brand of piston is common.
Jonathan Mirgon
04-08-2004 01:46:56
 Re: Re: H FARMALL AFTER MARKET FIRECRATERS? in reply to gene b, 04-07-2004 18:59:30
tisco alsp sells the conformatic pistons
