MICE!!!!!!!!
Jim K
04-10-2004 07:16:56
Just a note to everyone with an A, B, etc.. If you store your tractor outside, or anywhere there are mice, plug up the torque tube! Mice have almost filled up my friends tractor and he ran it quite a bit over the winter. Needless to say.....starter messed up ring gear, clutch is packed up and has now been laboring the motor when he pushes the clutch it, and the SMELL!!! A tractor split is now in order and I am always the local splitter in our little old tractor circle. Trust me, do not wait for this to happen. It is a mess!
scruffy
04-10-2004 19:24:14
 Re: MICE!!!!!!!! in reply to Jim K, 04-10-2004 07:16:56
A mouse cost me an engine on a ferguson. It crawled up the exuast pipe and filled the manifold and one cylinder with seeds. It cranked and fired and had a little trouble compressing weed seeds. Bent the rod and valves.
John *.?-!.* cub owner
04-10-2004 16:32:47
Their urine will also ruin the front transmission oil seal.
farmallsc
04-10-2004 15:33:08
i cant really split my super C so is there anyway that i can remove the mouse reminace without having to split it? or can i just leave it there and ignore the smell?
big fred
04-10-2004 14:46:10
I think on the A and B, the mice are factory installed. They're a special breed, rodentii farmallensis, also known as the "stinkymouse". I'm not sure an A or B will operate properly without them.
farmallsc
04-10-2004 12:40:57
that same thing has happened to me. i have a mouse nest on the ring gear, i have a super C could they get to the clutch too?
Jim K
04-10-2004 13:05:31
 Re: Re: MICE!!!!!!!! in reply to farmallsc, 04-10-2004 12:40:57
Oh yeah. All over. In front of the flywheel/ring gear, all over in the clutch and clutch dogs, filling the torque tube with everything they can find to put in. One more thing, a cat cannot eat as many mice as what come from the woods. Set traps, and stuff the hole underneath the tube with steel wool. That should deter them critters enough to go find a home in the neighbors yard!!
steveormary
04-10-2004 10:36:36
Jim, Mabe you friend should keep a few cats. I have had mice build nests on the manifolds around the exhaust pipe on my M but never inside the tractor. We always had a few cats on the farm.
steve
