Casting Numbers 101
Loren
04-10-2004 10:49:02
I have 2 113 inchers. The unbroke one has 3 rusted sleeves, wanting to transfer 2 from the cracked block and purchase another to complete it. Have located a source for the single set. Before going to all the work of pulling them to transfer can anyone tell me from the casting numbers if the sleeves will be the same OD and interchange? Serial is visible on only one of them. FAA 31??? Frame tag says '46 B. The two casting numbers are 6342DH and DE behind the oil filter. Thank you a lot. Loren
Jim Becker
04-10-2004 21:08:54
 Re: Casting Numbers 101 in reply to Loren, 04-10-2004 10:49:02
Blocks numbered 6342D[anything] should all accept the same sleeves.
Thank you sir.
04-10-2004 21:20:42
 Re: Re: Casting Numbers 101 in reply to Jim Becker, 04-10-2004 21:08:54
Loren
