560 TA ? need advise
joe
04-10-2004 16:26:00
The Torque Amplifier only works in low range (lever back). I checked all the adjustments and removed the cover on top of the T A clutch to observe the clutch engagement. It engages just fine, there is space between the fingers and the throw-out bearing, but the clutch slips, so I have no direct drive. I just had the tractor split and thought the clutch and pressure plate was OK, but it doesn't seem to apply much force to the clutch disk. And yes, I did remove the 3- 5/16-18 cap screws when I had the clutch and pressure plate off. I suppose I will have to split the tractor again, but I don't want to take the center clutch housing off. When I had it apart before the torque amplifier assembly would only turn in one direction. I thought it was because of the rollers running up on the ramp, or am I wrong? Is there anything I can check without completely removing the TA? The tractor runs fine other than no direct drive. Any advise would be appreciated.
RickB
04-10-2004 16:37:27
 Re: 560 TA ? need advise in reply to joe, 04-10-2004 16:26:00
Turning the TA one way only is normal; that is how a TA works in 'low'. Any TA clutch malfunction I can think of short of wasted splnes on front of the TA's carrier can be remedied by just a front (clutch housing) split.
joe
04-10-2004 16:50:45
 Re: Re: 560 TA ? need advise in reply to RickB, 04-10-2004 16:37:27
So I just split behind the engine and replace the TA clutch and pressure plate. Nothing could be bound up to keep the new clutch and pressure plate from turning the whole thing. I have this vision of lots of smoke from the new clutch.....
Thanks for the reply.
