350 drips oil
Evan350
04-13-2004 07:35:58
For years, the 350D had received a steady diet of non-detergent 30 weight when we changed the motor oil. On the last oil change I switched to 15W-40 and shortly thereafter it developed a leak when the engine is running at the base of the injector housing where it bolts to the engine block. I guess I'm not suprised lighter oil found a place to leak. However, before I take this apart, what exactly is the interface between the injector and the block? Is there a gasket there, or is it metal to metal? Would using the gasket-in-a-tube stuff work, or should I get a proper fitted gasket from the CNH dealer?
Chet
04-13-2004 18:21:12
 Re: 350 drips oil in reply to Evan350, 04-13-2004 07:35:58
Another thing to consider is just going back to the 30-w oil. Other than the gasket or o-ring drying out, what may have caused the problem is the ability of the newer class oils to 'creep'. We have experienced this on both Farmalls and Fords we have rebuilt. The new classes of oil actually have the ability to move or wick into or out of gaps or cracks that the older 30-w wouldn't. And yes it will appear to move up-hill along a timing gear cover. Some times it is just better to stay with what got it this far.
tractor dan
04-13-2004 13:01:37
i had the same problem with my 350 diesel i dont remember if there was an oring under pump or not but there is now and it dont leak any more you do have to remove pump and retime kinda a pane to retime correctly if have any prolems email me
Dave W V
04-13-2004 08:42:17
O ring used ,but make sure its engine oil and not diesel fuel leaking.
Evan350
04-13-2004 10:14:21
 Re: Re: 350 drips oil in reply to Dave W V, 04-13-2004 08:42:17
Definately engine oil.
