four wheel drive 706
nate
04-15-2004 19:07:12
i was wondering if anyone has ever switched a farmall 706 narrow front to a four wheel drive unit? is it a difficult switch? also, how hard are they to come by, and howmuch should i expect to pay if i do find one? i want a wide front, but a live one would be one up, and the picture in the front of my manual sure looks mean! i bet that an ih gear type front end would work alot better than a jd hydraulic type. thanks for any info. nate
w gatewood
04-15-2004 19:34:39
 Re: four wheel drive 706 in reply to nate, 04-15-2004 19:07:12
the axle was made by the american coleman co. it takes a fourty acre field to turn the tractor around in.
MEK
04-16-2004 06:36:13
 Re: Re: four wheel drive 706 in reply to w gatewood, 04-15-2004 19:34:39
Is that the hydraulic or mechanical front wheel assist? I thought the mechanicals were always built by an "Elwood Manufacturing Co."
Finding one that is not junk and/or already attached to a tractor is going to be tough.
FWIW, mounting it is easy enough; the early ones that fit the 706 have a cradle that bolts to the frame IIRC. Later ones from the 3088 era fit on the original kingpin, if I am not mistaken, but only on the much heavier kingpin of the later series tractors.
nate
04-17-2004 06:30:37
 Re: Re: Re: four wheel drive 706 in reply to MEK, 04-16-2004 06:36:13
thanks for the good info
nate
steveormary
04-15-2004 21:22:58
nate,could you go with a track kit. Always thought about doing that to mine.
steve
