Farmall Super A Tractor
Diane Gower
04-15-2004 20:00:24
We just purchased a Farmall Super A & cannot find the serial # or the dip stick to check the oil level. Thanks for any help!
Randy in NE
04-16-2004 04:19:20
 Re: Farmall Super A Tractor in reply to Diane Gower, 04-15-2004 20:00:24
The top petcock is the full level. You want to fill the oil until it is just starting to drip out of the top one. The bottom one is the low level mark. As long as you get oil out of this one you are ok. Your A has the same engine that my C does. It takes 6 quarts of oil to change the oil and filter. There are dozens of opinions on what is the best oil to use. It is a preference thing. Good quality oil is best. The oil filter can be purchased from your local Case/IH dealer or auto parts store. I just bought some from Case/I for about $5.00 a piece. There is an o-ring under the oil filter cap that needs to be replaced when you change the filter.
Wild Horses
04-16-2004 10:31:10
 Re: Re: Farmall Super A Tractor in reply to Randy in NE, 04-16-2004 04:19:20
I don't know about the A-B-C'S. But on an M if you can get the bottom petcock to drip, but not the top. We always figure it about a quart low.
Gerald
04-15-2004 20:14:51
The serial number plate on both of my A's is located on the left vertical seat frame support facing inward. It may be painted over. My A's do not have a dipstick. They have oil cocks ( little valves) located on the left side of the oil pan. Use a cresent wrench or pliers to turn the handle. There are two of them, each one at a different level. I always check the top one. Turn the handle counter-clockwise to open. Be careful as they can twist off easy sometimes. Good Luck....Gerald
