Super A Touch Control Unit
Frank Hurst
04-19-2004 09:29:27
I have replaced all the o rings in the Hydraulic unit and I cannot get any pressure at all. I have taken it apart again to see if I put anything in wrong but everything lines up with the manual drawing. With the filler plug removed and the engine running all I get is bubbling,install the plug and no pressure. HELP
WalJohn
04-20-2004 03:46:08
 Re: Super A Touch Control Unit in reply to Frank Hurst, 04-19-2004 09:29:27
Frank,
I just redid the unit on my uncle's 140. After doing all of the o-rings and seals, the check and control valves were so worn, they had to be replaced also.
Frank
04-20-2004 12:47:41
 Re: Re: Super A Touch Control Unit in reply to WalJohn, 04-20-2004 03:46:08
Thanks WalJohn, It was working somewhat before I replaced the seals,one bad valve and the strainer, now nothing, acts as if it is full of air but have bled it many times by the instructions in the owners manual. Frank
Shaggy
04-19-2004 15:27:42
I am about to tackle the same project. It looks intimadating but I have been told its not a bad job. I priced the kit does $90 and change sound about right? GAskets and seal kit.
Frank
04-19-2004 18:04:07
 Re: Re: Super A Touch Control Unit in reply to Shaggy, 04-19-2004 15:27:42
Shaggy, your price sounds about right, I got mine from Case. The job itself is not bad, pray you have a better outcome than I did. Frank
Dave_Id
04-19-2004 09:50:45
Did you properly bleed all the air out of the lines and unit?
Russ
04-19-2004 16:55:16
 Re: Re: Super A Touch Control Unit in reply to Dave_Id, 04-19-2004 09:50:45
Hyraulic Nightmare; Sounds like the hydraulic pump is cavitating on the supply side with an air pocket or head of air. Better read the manual completely in this section and figure out how to purge the troublesome air. Has got to be it.
Frank Hurst
04-19-2004 11:08:51
Thanks,Dave, yes I think I purged the air. I followed the instructions in the IH Farmall service manual. Frank
