Farmall A won't start
Bigdog
04-20-2004 10:17:39
have a Farmall A that got overheated (real hot) now won't start not even a pop when i crank it have put in new points, plugs, compression is 90 lbs in every hole, ran perfect before it got hot
Bigdog
04-20-2004 15:11:35
 Re: Farmall A won't start in reply to Bigdog, 04-20-2004 10:17:39
have good spark but the plugs are dry but i know it is getin gas to the carb. checked the timing is timed right, good spark, gas to carb, good compression, should run but it don't
(The other) Bigdog
04-20-2004 16:55:13
 Re: Re: Farmall A won't start in reply to Bigdog, 04-20-2004 15:11:35
When it got hot you may have warped the head or manifold. If you have gas to the carb, it sounds like it's not getting to the cylinders. You might try dribbling a little gas in each cylinder, replacing the plugs and see if you get any firing at all.
Jeff In Ontario
04-20-2004 11:23:36
The first thing i'd check is the coil, chances are that it is toast --Jeff
cjpenny
04-20-2004 11:14:12
BigDog
does the plugs have spark? did you brun up the coil? if the plugs have spark are they getting gas? are the plugs wet or dry? these things will help us figure it out.
Chad
