Super A hydraulic cylinder head hard to remove
Walter
04-20-2004 12:13:27
I removed the hydraulic cylinder from my '52 Super A to relpace orings and gaskets. The cylinder head will not budge after removing the 14 bolts. I have the Touch Control Serviceman's Handbook (GSS-1024) but it doesn't help here. I was wondering if anyone ever run into this problem before that might give me some pointers on how to safely remove cyinder head. Thanks in advance.
scotty
04-20-2004 12:33:54
 Re: Super A hydraulic cylinder head hard to remove in reply to Walter , 04-20-2004 12:13:27
Walt, That cylinder head has been on ther for 52 years, it will need a little persuasion. Try tapping with a babbit hammer. If no luck you can try a thin steel wedge between the cylinder head and gasket, you can also try some liquid wrench or other similar solvent. Good luck.
scotty
Walter
04-20-2004 18:26:37
 Re: Re: Super A hydraulic cylinder head hard to re in reply to scotty, 04-20-2004 12:33:54
Thanks Scotty. I tried tapping around cylinder head with a pine block with no luck - didn't think gasket sealer would be that tough. I didn't want to get too rough and crack something. Your right though, it's probably been on there 52 years and needs some persuasion.
