544 Utility Carb question
Ibby
05-01-2004 04:59:09
I inherited my Dad's 544U last year and am trying toi get it functional again. Since the tool he liked best was a hammer, that's what he fixed everything with. THe carb (And manifold - he had an anger manegement problem) got smashed the last time it wouldn't start. I took the pieces to several dealers and repair shops and was told by all that it was no carb they have ever seen before, and may have been something put together from pieces of several other carbs. The parts manuals and catalogs list 3 different carbs for this model. Some with a fuel shut off solenoid, some without. First question is - How do I determine the best carb to buy, 2nd, is the fuel shutoff solenoid necessary or at least reccommended?
rebuilder
05-01-2004 18:39:54
 Re: 544 Utility Carb question in reply to Ibby, 05-01-2004 04:59:09
Ibby;
I cease to be amazed anymore with things I see coming into the salvage yard. My guess would be that someone found a carb from some other application which would fit. As for the three carbs which the book calls for I will list them and give you my opinion(such as it is)on each.
The three carbs are a marvel-schebler Part#398069r92---Zenith part#405030r91---I.H. part#406804r91. I would first use the I.H. carb. It is built well and you can still get most of the internal parts for it. Secondly go to the zenith. The biggest drawback is they are made out of pot metal and most I get in to be rebuilt have the threads stripped out. Otherwise it to is fairly common and easy to get parts for. I would not, however use the Marvel-schebler carb. While they are the heaviest built of the three carbs, I have found you cannot find the parts to rebuild them. Especially the jet which goes into the fuel shutoff.
All three carbs have the option of a fuel shutoff but you do not have to use them. I actually have had to put together main adjusting needle/packing/packing nut kits for many guys who use these to help adjust the fuel mix in the I.H. carbs. The Zenith carbs you can also put an adjusting needle in but I have heard they are not as useful but do serve to remove the fuel shutoff.
Ibby
05-02-2004 03:12:00
 Re: Re: 544 Utility Carb question in reply to rebuilder, 05-01-2004 18:39:54
Thank you very much for the info. If you would email me at ibby458@yahoo.com, I'd like to discuss some purchases, if you sell these carbs.
