450 ta help please
Tom Murphy
05-01-2004 11:39:53
Hello again.I hope i dont bother you guys with to many questions..the 450 farmall i bought has the torque amplifier but the guy i got it from said it doesnt work and didnt when he got it either.is this a hard item to fix? what could be the problem? do i really need it? also brake hardwear is gone on one side, is this a hard item to find or very expinsive? I am new to old tractors but allways wanted one. if i ask to many questions just tell me.. Thanks in advance..Tom
Farmall450man
05-03-2004 06:03:31
 Re: 450 ta help please in reply to Tom Murphy, 05-01-2004 11:39:53
Tom, you can get brake parts from JP Tractor Salvage,>Link
Steel>Link Wheel Ranch also sells rebuilt TA units.
Good luck.
tim
05-02-2004 04:28:29
check to make sure the linkage for the TA is correct. a manual will show the correct adustments. i bought a 350 once that "quote" the TA was out but all it was to fix it was adjustments.
Red Rider
05-01-2004 19:40:35
Tom, If your tractor goes fine when the TA lever is forward then this indicates that your TA clutch is not slipping. If when you pull the TA lever back and your tractor stops then the ramp and roll overrun clutch is shot. The TA is a handy item and you would not be without it once you have used it. The best solution in my opinion is to replace the ramp and roller over run clutch system with a sprague unit. They are a lot stronger and most likely will last your life time. I have replace the TA in three of my tractors with the sprague unit and all work very well. When I replaced the TA unit I replace Main clutch and pressure plate, The TA clutch and pressure place plus both throw out bearings all for under 900 dollars.
Kelly C
05-01-2004 15:34:30
If the tractor works with the TA handle forward. Then you tractor is in direct drive. Works fine that way, as if it did not have a TA.
I put a rebuilt TA in my 400 this winter. It cost $499 + $100 core charge. Then another $60 for seals. It is not that hard to fix just time consuming as you do need to split the tractor.
Plug the link provided and click on the 400 page tab on the left side of my web site. I documented the procedure there.
Farmall43
05-01-2004 13:18:56
The only stupid question is the one not asked. As for the T/A it depends on what you aare going to use the tractor for. If you plan on working it hard then it could be nice to have. But it is not essencial for the operation of the tractor. As for what could be wrong I do not know. I only know that it cost the previous owner of my 400 about a grand to replace the one in it. Welcome to the addiction and good luck.
