IH 3 pt problems
wade
05-06-2004 07:15:40
The 3 pt on my IH966 does not go down nice and smooth when you have anything very heavy on it. If you move the lever very very slowly it will go down easy. If you work it like it should be it drops about say 2 inches at a time. I have a sprayer on it and it seems it would like to jar the heck out of it whenever you try to lower it some. Someone must have ideas on this.
jim
05-06-2004 16:46:42
 Re: IH 3 pt problems in reply to wade, 05-06-2004 07:15:40
I have found, thru working on several "66" and "56' series IHC tractors that there is either wear in linkage, or else the control spool for the 3 pt is sticking..... usually removing the top cover and going thru the linkage and resealing the 3 point control spool and related valves will solve the problem of slow/erratic operation
good luck!
Allan
05-06-2004 08:31:30
Wade,
Excuse the obvious, but do you have your draft control down where it belongs?
Allan
wade
05-06-2004 08:36:11
 Re: Re: IH 3 pt problems in reply to Allan, 05-06-2004 08:31:30
well i have tried it with the draft control on light and heavy and all in between and still the same affect
steveormary
05-06-2004 09:35:16
 Re: Re: Re: IH 3 pt problems in reply to wade, 05-06-2004 08:36:11
Wade, I think you do have to move the lever slow to have a heavy implement drop smoothly. That is the way it was on my 706 german.
steve
wade
05-06-2004 09:42:40
 Re: Re: Re: Re: IH 3 pt problems in reply to steveormary, 05-06-2004 09:35:16
I guess its more like not slow or fast but its does not go down smooth. it just drops inches at a time.
steveormary
05-06-2004 10:35:06
 Re: Re: Re: Re: Re: IH 3 pt problems in reply to wade, 05-06-2004 09:42:40
Wade;
dont know what to say about that.
steve
