Front Cylinder For Fast Hitch
David
05-09-2004 22:10:25
I just bought a 300 w/fast hitch. It has mounts on it for a front cylinder along with a hydraulic outlet. I want to buy a cylinder to replace the missing one. What length/diameter do I need to buy?
What is the purpose of this front cylinder?
Wardner
05-09-2004 23:16:59
 Re: Front Cylinder For Fast Hitch in reply to David, 05-09-2004 22:10:25
2.5" x 8".
I recommend that you get an original made by IH. The overal pin-to-pin lenght both open and closed will be perfect. I bought 2 from Bates Corporation, an IH dealer in IN.
It controls the angle of attack of the plow which has an influence on the depth of the furrow.
It will also extend the range of the lift by eight or more inches. This is handy when traveling with mounted equipment.
Hugh MacKay
05-10-2004 18:20:38
 Re: Re: Front Cylinder For Fast Hitch in reply to Wardner , 05-09-2004 23:16:59
Wardner: Those cylinders are they the exact mate of the IH stroke control implement cylinder? I know when I removed the fast hitch from my 300, I used both for implement cylinders, but can't remember if stroke and lenght are exactly same. I know they are close.
