Constantly discharging
jjw
05-19-2004 11:11:19
What is the easiest test to dicifer whether or not the wires are connected correctly for a positive charge??? jjw
gene b
05-19-2004 19:55:21
 Re: Constantly discharging in reply to jjw, 05-19-2004 11:11:19
With a volt meter check which gives you a reading pos to the ground or neg lead to ground. If you want the original set-up the batt should have the pos terimal to ground.
Bigdog
05-19-2004 11:54:14
Place a voltmeter across the battery terminals. If battery voltage reads higher with the engine running than it does off, it is charging. If it reads the same or less, it is not charging.
gene b
05-19-2004 19:48:17
 Re: Re: Constantly discharging in reply to Bigdog, 05-19-2004 11:54:14
HE wants to know which is ground not what the voltage reads.
jjw
05-20-2004 06:22:46
 Re: Re: Re: Constantly discharging in reply to gene b, 05-19-2004 19:48:17
I tried to switch the cables on the battery from neg ground to pos ground and the sparks flew, so back the other way I went. The voltometer test showed no increase on the battery when running. Could there be a polarization problem?? Another guy told me the 450's where neg ground origally?? jjw
