Changing H Brake Bands
Garrison
05-20-2004 06:41:43
Can somebody give me a good procedure on hoe to dhang H Brake Bands Please
TDK
05-20-2004 21:08:26
 Re: Changing H Brake Bands in reply to Garrison, 05-20-2004 06:41:43
Don't forget to check wear on drums. Most seem to be worn in the center. It took a good .080 to true the drums on my M.
jcnc
05-20-2004 13:26:43
Remove levers and spring from brake cover.
Remove adjustment screw at bottom.
Remove bolts holding cover and remove it.
Remove brake bands.
Remove seal around shaft from differential. (This can be difficult. Be careful to not break the casting)
Replace seal.
Replace brake band (seals and bands are available from the IH dealer).
Put everything back together. I found I didn't need to screw the adjustment screw in very far.The new bands and linings were a tight fit.
Adjust brake pedal as needed.
I hope this helps. I did the brakes on my "H" but it's been a couple of years so I hope I didn't leave out something.
