M hood
Ted
05-21-2004 04:56:52
On the top center of the hood on M's and Supers there is a wingnut the fastens to a threaded stud that helps tighten up the hood placement. What size is it? It looks like 3/8 inch but is not. Also, I can't find a metric that I thought would mate a possibly worn thread. Thank You
Novel Idea Guy
05-21-2004 13:18:06
 Re: M hood in reply to Ted, 05-21-2004 04:56:52
If the threaded stud doesn't hold on to a 3/8" wing nut, it's probably stripped and/or worn down.
nebraska cowman
05-21-2004 08:30:18
I can't find it in the parts book. It calls for part number 60707D I'm sure it's 3/8
JON
05-21-2004 09:10:19
 Re: Re: M hood in reply to nebraska cowman, 05-21-2004 08:30:18
HI, I have tryed three times to post this morn it keeps saying wont let me so I will try it again. Yes it is 3/8 16 I measured my Super M this morn. also checked it with tap and die set . Go to your local tractor supply if you have one and look in the sliding hardware section. THANKS JON
