Farmall H Decal Removal
Jeff In Ontario
05-21-2004 09:53:57
Hi fella's , i've got the day off today so i'm working on my H. The question that i have is: what is the best product to use to remove 10 year old decals from the hood. I need to get them off to fully sand it then repaint it. Any help is much appreciated! ---Jeff
John *.?-!.* cub owner
05-21-2004 20:00:33
 Re: Farmall H Decal Removal in reply to Jeff In Ontario, 05-21-2004 09:53:57
If they are the adhesive type rather than the water slide off ones go to Home Depot and get some Goo-Gone. Second choice would be UNDU from Walmart.
Steve from Mo. heat gun.
05-21-2004 11:13:32
You could just start sanding if the decal is old and brittle. If you really want that decal off before you sand, a body shop heat gun (like a big hair dryer) or careful use of a propane torch will soften the decal so it can be scraped off.
nebraska cowman
05-21-2004 10:19:08
elbow grease. They come off with a sharp putty knife if you can get under the paint.
