Just when I thought I knew it all!
Carp
05-27-2004 14:25:58
I just recently had a problem with my newly rebuilt 450 gas. This one took a while to figure out since I had just come in from discing 5 acres. After replacing the bendix on the starter, I started the tractor up and it ran on just 1 cylinder. I shut it down and refired a couple of times and it still ran on just 1 cylinder. Over the course of the next couple of days I fiddled and checked just about everything. Then in an attemp to find out which one was firing, I pulled off the plug wire on #1 cylinder. Then it ran on 3 cylinders. Put #1 back on and ran on 1 cylinder. After some noodling around, I decided to change the distributer cap. That fixed it. I came to find a very fine crack in a otherwise very good looking cap. This crack was arcing over to #1 cylinder, which allowed #1 to fire but pulled current from the other 3 when they tried to fire. When I unpluged #1 plug wire, that left it so it wasn't grounded and the other 3 got full spark.
I thought I knew quite a bit about gasoline engines (especially old Farmall's), but this one had me stumped. Sometimes these ole tractors really throw you a curve. Does anyone else have any real stumpers they have run across.
Bruce Wa.
05-28-2004 19:07:54
 Re: Just when I thought I knew it all! in reply to Carp, 05-27-2004 14:25:58
had the same thing on an old clark forklift. had to pull on wire then it ran fine on 5.
kev@ia
05-27-2004 17:11:39
You just don't expect to pull off a wire and the motor runs better!
Hugh MacKay
05-27-2004 16:16:49
Carp: Same as you about 20 years ago, different sequence of cylinders but problem and solution were the same.
In fact I had quite a run on distributor caps back then. Seemed like every 6 months I was buying a cap. I wondered had IH or CaseIH farmed the manufacture of these out to a cheap supply. It seems better now, don't think I've bought a cap for 5 years.
