TA rebuild, but not all bad
Chris Brown
05-27-2004 19:40:22
I have a 560 that the ta has'nt worked in 10 years. I have it apart and all I can find wrong is the ta clutch throwout bearing went through the pressure plate and the ta one way clutch(ramp and roller) is bad. The planetary's are fine. Can I just put in the parts that it needs? Can I get these parts? Where? This is a loader tractor and it does not get alot of work especially any hard work.
rebuilder
05-28-2004 04:33:04
 Re: TA rebuild, but not all bad in reply to Chris Brown, 05-27-2004 19:40:22
Chris;
T.A.'S are not extremely hard to do, but the main thing is to check all bearings and bearing surfaces where needle bearings ride. the needle bearings I replace if I canput an o ring pick into the needles and create a gap. Also use new needles for the planetary gears, no execptions. Lastly I grind all the carriers where the ramp rollers ride to create a smooth surface. However, if your surface looks smooth as a bearing cone surface then you should be fine. I get my parts from several different wholesale suppliers and I.H. If you have trouble getting parts post me back though this site.
