Farmall B won't start HELP!
Farmer Steve
05-29-2004 05:48:34
I started up the B and it was running fine. Drove it to the drivway and pressure washed it and now it won't start. I know! I checked the distributor and it was dry as a bone. I have an A also so I changed the condencer and coil thinking I killed them, but they were good I don't know what else to check. I have cleaned it many times like this and never had a problem. Help please. Thanks in advance Steve!!!!!
LWWinPA
05-30-2004 04:49:53
 Re: Farmall B won't start HELP! in reply to Farmer Steve, 05-29-2004 05:48:34
spray with WD40 it should start
Jon
05-29-2004 06:19:55
I forgot I would also spray every thing with a wire dryer including wires, and coil wire, inside cap, where coil wire goes in to coil, And check your conections. JON
JON
05-29-2004 06:16:17
Have you checked for spark at the coil wire or plugs?
