H or Super H?
D.Miller
05-29-2004 05:58:22
How can I tell if I am looking at a H or a Super H.
Paul in Mich
05-29-2004 06:37:50
 Re: H or Super H? in reply to D.Miller, 05-29-2004 05:58:22
D Miller, If you have a serial number ID plate, you can check the serial number against the serial numbers listed in the left hand menu under "research and info". If you have no ID plate, you can check casting dates and if it is a super, the date will have a "Y" or "Z" meaning 1953 or 1954. A super H will also have disc brakes.
Hugh MacKay
05-31-2004 02:54:59
 Re: Re: H or Super H? in reply to Paul in Mich, 05-29-2004 06:37:50
Paul: Close but not 100%, a few H's had disc brakes. My dad bought a new H in 1951 and it did have IH disc brakes. I have recently heard of a couple others, and all 51 models.
I'm not so sure a few other SH items didn't come on some of the last H's Our H had Super type front wheels, but that had been around couple years on other Supers. I have no way of knowing for sure but wonder if some of those last H's didn't have the SH engine. Dad also bought a new 300 in 55, and the only advantage we could see was TA, and not the great power difference you read about here in discussions. We used the same 2x14 plow, 8' disk and 9' cultivator on both tractors.
Jon
05-29-2004 06:14:07
Serial # , Larger carb,May have live hyd,If you cant see the serial # I would say that the larger M style carb would be the give away. JON
