300 utility exhaust manifold
dave
06-01-2004 04:41:24
This past week I posted about an exhaust leak that I have on my 300 utility.What I see and feel is a large opening directly in the middle and on the bottom of the manifold.There seems to be a lot of the tractors exhaust comming out of this opening. It is about 3-4" long and about 1/2-3/4" wide. Is this normal. Should this opening be there? thanks for any help dave
Red Rider
06-01-2004 20:01:14
 Re: 300 utility exhaust manifold in reply to dave, 06-01-2004 04:41:24
No Dave there should not be an opening the size you mention. The stock vertical exhaust manifolds for the 300 and all 4 cylinder gas engines have a 1/8 inch diameter hole on the bottom of the center two exhaust manifold ports. These were their for water to drain if no cap was on the exhaust. The under slung manifold probably did not have these weep holes.
Ken in Iowa
06-01-2004 17:35:33
A 300U normaly has an exhaust pipe with a muffler under the left step and a tailpipe out the rear. The exhaust pipe is connected to a flange on the bottom of the manifold. It sound like your manifold is broken. Ken
