H Cylinder heads
Pat B in Mich
06-02-2004 21:56:49
I have a H head w/casting #6186DD for(Kerosene)
this head had Gasoline valves in it. However it is bad shape and needs to be replaced. Can anyone tell me if the 8043D(Gasoline) Head can be used instead of the 6186 head?? The 8043 head is more abundant.Is the bolt pattern the same on both and are they the same size or any major differences? Is this possible
Theman
06-03-2004 12:19:32
 Re: H Cylinder heads in reply to Pat B in Mich, 06-02-2004 21:56:49
The 8043 head will give you a bit more power (higher compression). The valve lengths are different for the three head configurations - kero, distillate, and gasoline - so make sure you have the correct valves or you will have a difficult time adjusting the rocker arms.
Chad from Michigan
06-03-2004 07:30:11
I have a head to match your old one if you are interested.
Chad
nebraska cowman
06-03-2004 03:21:45
the heads will interchange
