Priming the belt pulley lubrication - '47 H
Dave in CT
06-03-2004 14:02:25
I've never used the belt pulley but am planning to soon. I've read somewhere that one is supposed to initially put some gear oil in through the filler hole at the top of the belt pulley drive mechanism - it looks like a 1" hole. After that the oil quantity there will be maintained through the operation of the transmission. I can't find what I originally read but I've added a pint of gear oil, engaged the pulley drive while doing some other chores and then took a look. The gears still looked pretty dry. What am I doing wrong? Adding too little? Adding it in the wrong opening? TIA.
Bob M
06-03-2004 14:59:42
 Re: Priming the belt pulley lubrication - '47 H in reply to Dave in CT, 06-03-2004 14:02:25
Dave - You did it OK! The belt pulley gearbox is lubed by oil thrown up by the tranny gears when it's in operation.
So long as the transmission lube level is up to the level check plug (left side of the transmission) the pulley gearbox will be fine.
In doubt? Try running the belt pulley briefly with the fill plug removed - you will see how it's lubed!
