Farmall 400, 450, 460, 560 Hydraulic gpms
Old Farmall guy
06-10-2004 15:21:19
How many gpms does the hydraulic system on a 400, 450, 460 and 560 put out?
DRN
06-11-2004 06:21:51
 Re: Farmall 400, 450, 460, 560 Hydraulic gpms in reply to Old Farmall guy, 06-10-2004 15:21:19
400-450 pump & system different from 460-560, cant find exact specs on 400-450, I do know they havent got much gpm or pressure, 460-560 was 12gpm std, 1500 psi,same pump as 656-706-856-1456 and 66-86 series, this pump could replaced with higher gpm, relief cartridge could be 1750-2000-2250-2500, 15gpm or 17gpm.
Red Rider
06-10-2004 19:29:58
There was only one pump available for the 400/450 and it was 12 gallons per minute. I don't know about the 460/560.
Hugh MacKay
06-10-2004 18:04:31
Old Farmall Guy: If I remember correctly they all had two options. I don't remember the figures for 400 and 450. The figures of 12 and 17 gpm ring a bell on the 460 and 560. It has been a long time, so I will stand corrected. At least this will get some people thinking. Put it this way, I'm 95% sure on the two options and about 50% on those exact figures on volume.
dhermesc
06-11-2004 05:45:39
 Re: Re: Farmall 400, 450, 460, 560 Hydraulic gpms in reply to Hugh MacKay, 06-10-2004 18:04:31
If I recall correctly the 12 gpm pump was used on the SH, 300 & 350 and the 17 gpm was used on the SM, MTA, 400 & 450. Have no idea what was used on the 460 & 560.
